Author Topic: 1968 Mustang exhaust leak  (Read 13247 times)
wcm3232
racedraper
Re: 1968 Mustang exhaust leak
  • Guest
wcm3232
wcm3232
Thanks for the help.
  • Guest
wcm3232
  • Guest
  • Guest
  • Guest
Ken Moore
bernie
mustangluver
  • Mustang: 66 coupe 289
« Reply #12 on: August 28, 2009, 09:36:13 PM »
your floor could be rotted as well. check the firewall, floor and the trunk
« Reply #13 on: August 28, 2009, 10:10:56 PM »
This thread is like 4 years old.  I haven't heard from these posters in several years.   ;D
mustangluver
« Reply #14 on: August 28, 2009, 10:14:21 PM »
lol it gave me the lil warning. the world may never know wat he ended up doing however.
Last post July 24, 2008, 06:33:33 AM
by SNAKEPIT
Last post December 19, 2008, 11:11:15 PM
Last post October 04, 2009, 04:25:24 PM
by mustangluver
Last post March 30, 2010, 11:02:23 PM
by mustang245
Last post October 02, 2011, 05:42:22 PM
by rmodel65
