Author Topic: 1966 Mustang- remove pushrod from master cylinder?  (Read 4597 times)
bandit1
« on: August 15, 2008, 06:35:18 PM »
How do you remove the pushrod from the master cylinder? I understand that I need to use it when changing from single mc (from 66) to dual mc (from 67).
Re: 1966 Mustang- remove pushrod from master cylinder?
« Reply #1 on: August 15, 2008, 09:42:38 PM »
It is difficult to do without the 'proper' tool. The 'proper' tool is difficult to locate. Without the 'proper' tool, something gets destroyed.
A 65 brake push rod is a lot easier (hint).
« Reply #2 on: August 16, 2008, 04:20:31 AM »
They make a special tool to remove the clip. You can try to use needle nose pliers  to collapse it enough to get a small screwdriver in between the master cylinder and the clip and then snap it out. If you contact Snap-on, and explain the exact problem, they can probably send you the correct tool to do it.  But, like Jim said.  The 65 rod just pushes right in without a retaining ring.
4thofdmont
  • Mustang: 1995
  • Daily driver: ford
« Reply #3 on: January 20, 2012, 08:42:54 PM »
here's what i did to remove the pushrod from the master cylinder. clamped the master cylinder in a vise with the pushrod pointing downward. With a round prybar in the pushrod hole, I gave the prybar one good smack with a brass hammer. The end of the pushrod was a little nicked up from the retaining spring breaking
Last post August 02, 2005, 09:04:08 AM
by msw1968
Last post July 31, 2008, 06:16:18 PM
Last post October 13, 2009, 06:30:35 PM
Last post November 22, 2009, 02:48:45 AM
by Tim175
Last post August 31, 2010, 04:21:39 PM
by Topless_Horse
