They make a special tool to remove the clip. You can try to use needle nose pliers to collapse it enough to get a small screwdriver in between the master cylinder and the clip and then snap it out. If you contact Snap-on, and explain the exact problem, they can probably send you the correct tool to do it. But, like Jim said. The 65 rod just pushes right in without a retaining ring.
