Author Topic: 1965 Coupe cooling problem  (Read 1892 times)
rboboc
  • Mustang: 1965 Coupe
  • Daily driver: Toyota Matrix
« on: July 19, 2014, 07:16:37 PM »
My cooling fan is not turn off after I shut the car off.  It ran for a few hours and killed the battery.  I unplugged the battery and discovered that the cooling fan comes on again only after I start to connect the (-) battery wire.
Any help would be appreciated.
Robert
Topless_Horse
  • Mustang: 66 convertible
Re: 1965 Coupe cooling problem
« Reply #1 on: July 20, 2014, 06:25:11 AM »
How is your fan wired?  Is there a relay in the circuit?  If so, check that to make sure it is opening and closing properly.  Also be sure that the fan thermostat is working correctly .
rboboc
« Reply #2 on: August 01, 2014, 01:40:51 PM »
Thank you for the reply.  Turns out there was a switch installed to control the power of the cooling fan.  I must have turned it on while cleaning the car.  I feel silly, but glad I figured it out.
Topless_Horse
« Reply #3 on: August 01, 2014, 07:16:29 PM »
I'm glad you found the problem.
You should NEVER feel silly when you solve a problem.  Always remember - the definition of "experience" is "the ability to recognize a mistake when you make it again"  :D
