Author Topic: 10.5:1 Compression in a '73 351C  (Read 9168 times)
sharpshot
« on: August 30, 2005, 08:11:33 PM »
Would it be safe to put a 10.5:1 Compression in my 351C. To run regular gas, if not how about premium. I have seen kits for the 10.5:1, it says that is calculated bored .030 over, so if mine is the stock size, that would lower the compression just a little bit right?
racedraper
Re: 10.5:1 Compression in a '73 351C
« Reply #1 on: September 02, 2005, 04:19:47 PM »
you should have no problem with fuel untill you really modifi it, does yous use reguler LEADED gas like mine?
you dont need to go to lower compression unless you add a 6:71 blower. Correct me if Im wrong anyone. but you will loose torque which the cleveland is known for..
cjmustang
« Reply #2 on: March 11, 2006, 10:22:02 PM »
Whoa, do not run regular gas with 10.5.1 period. My mustang came with 4 bbl closed chamber (boss) heads and the compression would be 10.5.1 and the machine shop said that youll break pistons if you did it long enough. You'll have to run on octanes higher than 96 or 97 im pretty sure. This is what happened to me and i had to buy lower compression (open chamber) heads.
Last post November 24, 2009, 05:02:50 PM
by Jeff73Mach1
Last post December 14, 2009, 11:52:19 PM
by Boss351Dude
Last post May 22, 2010, 01:26:24 AM
by Tim175
Last post February 04, 2011, 09:00:25 AM
by thundertc64
Last post February 04, 2012, 03:17:07 AM
by 4thofdmont
