  • December 05, 2008, 08:13:36 AM *
  • Welcome, Guest
John Forces Mustang
Mustang girl
100 0807
Soaring's cars
myllpny pictures 002
Author Topic: Bodywork with a flux cored welder?  (Read 3524 times)
  • Thierry
  • Administrator
  • Daily driver: Sunfire
    • WWW
« on: February 17, 2008, 06:05:57 PM »
Re: Bodywork with a flux cored welder?
« Reply #1 on: February 18, 2008, 03:31:41 PM »
I use three different types of welding on my cars depending on the situation - gas, arc and wire with argon. Ford used a lot of spot welding and lead filler in the assembly line but none of those others, and they did not repair panels or do body work like we are faced with. Almost any type of panel welding is going to cause warpage so invest in some Eastwood welding aids, clips, clamps, etc, and practice, practice, practice.
  • Thierry
  • Administrator
    • WWW
« Reply #2 on: February 18, 2008, 06:46:36 PM »
xnutt
« Reply #3 on: February 18, 2008, 11:29:41 PM »
  • Thierry
  • Administrator
    • WWW
« Reply #4 on: February 19, 2008, 11:36:32 AM »
 Thanks, the more stuff I get to make nicer welds the better it is.
Yes a flux core welder is a MIG one without the gas. The problem is that the gas is supposed to make cleaner and stronger welds. I don't have any structural parts to weld so I guess it won't be too bad but I will probably have to find a better one to fix the thicker metal of the floor.
Mark57
« Reply #5 on: May 24, 2008, 12:29:41 AM »
I first used a flux core welder and found that after some practice I got pretty good with it.Then after getting a MIG welder I found better control in ease of welding and less slag to clean up. So its a matter practice and patience 8)
  • Thierry
  • Administrator
    • WWW
« Reply #6 on: May 24, 2008, 01:35:53 PM »
« Reply #7 on: May 28, 2008, 12:05:55 AM »
So... Where are the pics.  I Want to see how my Canadian friend welds .
  • Thierry
  • Administrator
    • WWW
« Reply #8 on: May 28, 2008, 09:26:00 AM »
 Well, like I said the welds are not perfect so I want to wait to be done to show the final result :)
I am painting the area with a roller and it takes a lot of time and work.
 Yes, I hear you saying "Is he nuts"?  :D This method is getting popular and the magazine "Hot Rod" painted a Ford Falcon with great results for a total cost of a $100. If you want to read the hundreds of pages in a forum discussion where it all started, it's here: Paint job on a budget
    • WWW
« Reply #9 on: May 29, 2008, 09:43:46 PM »
yeah ive seen that, thats crazily time consuming. personally id go for some 2k and a buffer :P
  • Thierry
  • Administrator
    • WWW
« Reply #10 on: May 30, 2008, 12:36:49 PM »
 Yes, it took me for ever to paint with this method but I had to test it and now I know that I will never paint an entire car with a roller  :D
Here is the photos of my work. It looks crappy and it needs a few more coats of paint, wet sanding and a buffer but I think it will stay like it is. It will now pass the inspection and it will last a few years  ;D
The total cost for the job is only $80 including the paint and all the material used. The welder's cost is about $300.00 but a better one can be rented for a lot cheaper.
 For that price there is no excuse to fix holes with bondo   ;D
« Reply #11 on: June 04, 2008, 01:53:00 PM »
I'm wondering how much rust is on the other side.  Yeah, but with maybe another layer of paint and wet sanding she'll look pretty good, at least for a few years.  Good job Thierry!
  • Thierry
  • Administrator
    • WWW
« Reply #12 on: June 05, 2008, 10:52:40 AM »
 The location on the photos was the only one with holes but I had to sand and paint a few other places to remove surface rust. It looks worse on the pictures than when you look at the car but we'll buy a new one after the summer and until then we have a car that looks decent enough  ;D
« Reply #13 on: June 05, 2008, 02:00:10 PM »
Yeah, I'm surprised at how little rust there is if you use that as a daily driver in the winter with the salt covered roads.  I had a 316I Beamer in Germany for 4 years, and even though I bought used, it had very little rust after the 4 years, and the Krauts salt their roads heavily.  I found out that BMW dips their cars' bodies in zinc before painting them.  Works.......
But, the big three in the U.S. have no thought of having their cars last more than 4 or 5 years, so use as little rust prevention as possible.  I think if I bought a new car and had to drive it in the salted snow country, I would POR 15 the hell out of the undercarriage before I put one mile on it.
  • Thierry
  • Administrator
    • WWW
« Reply #14 on: June 05, 2008, 03:58:08 PM »
 We only had this car since the past 3 years and before that it was used as a second car and was kept in a garage. That explains why there is not much rust. The holes I fixed came from a pin hole in the rocker panel under the door. Water came in from there and stayed in the back of the rocker.
 European cars have a 10 or more years warranty against rust perforation in Europe but I have seen German cars in Canada much younger than that with a lot of rust damage. 5 or 6 months driving on salted roads makes a big difference compared to the 2/3 months they have where I was based in Germany.
