Author Topic: 72 coupe roof progress, hoping it can be saved...  (Read 2502 times)
Meric
  • Mustang: 1972
« on: May 31, 2010, 04:53:47 PM »
ok doing roof of a 72 coupe in 2 sections, front and back.  Starting with the front since that is where the rust seemed the most threatining.  Have it sanded and stripped from window to 8 in. back all the way across. There are several 'dimples' across the top in a couple of spots, with those I sanded down to the sheet metal 1 1/2 inches out around the dimples.  Sanding was done with a 60 grit paper to allow plenty of grip for the bondo.  I could not locate POR 15 and ended up going with Klean-Strip Rust Remover and is design to desolve and neutrlize rust.  Letting it sit and desolve rust for another 45 minutes then on to bondo/filler.  Any suggestions or concerns please leave a post.
Re: 72 coupe roof progress, hoping it can be saved...
« Reply #1 on: June 27, 2010, 03:36:00 PM »
are you welding the holes closed before filler? you do know that filler absorbs water right? at min i would be putting fiberglass mat/resin down before the filler....
