Author Topic: Transmission problems please help!  (Read 5252 times)
kakarotto05
« on: March 08, 2008, 07:48:24 PM »
I just installed a new clutch in my 88 gt mustang. After i got everything back put together and adjusted the clutch to the proper spot, i'm having a difficult time engaging the tranny in 2nd, 4th, and reverse. Is there any alingment that i needed to do to the transmission to prevent this or what can i do? Also there is a humming noise, possibly coming from the throwout bearing but it only makes the noise when the car is in neutral, any ideas what this is and how to fix it? I installed a brand new clutch, pressure plate, throwout bearing, retaining bearing, and clutch cable w/ firewall adjuster. Thanks!
Re: Transmission problems please help!
« Reply #1 on: March 09, 2008, 03:20:45 AM »
You still don't have your cable adjusted properly.  Consider getting a firewall adjustable quadrant.  You can get those at Summit.  They have the entire clutch cable package.  I put one in my nephew's 02 GT in one afternoon, so it's no big deal.  The self adjustable quadrant is a POS.
zebo87
  • Mustang: 87 gt
  • Daily driver: 87 gt
« Reply #2 on: March 09, 2008, 09:43:35 AM »
also i cant remember but if you pull the boot on your shifter there is a set screw for the shifter. i know there is one for 1st, 3rd, and 5th but i cant remember if there is one for 2, 4, r. i had a problem where i couldnt shift to 1, 3, or 5 and that was the problem. the screw rattled forward and wouldnt let me engage those gears. just an idea.
« Reply #3 on: March 09, 2008, 08:16:46 PM »
Nah, you don't want to go messing around with those screws.  Just get a Steeda short throw shifter and be done with it.  That shifter just guides the tranny into each gear without any effort.
The original 3650 shifter is a POS.  Here, I'll make it easy for you to order it.
http://www.steeda.com/products/steeda_triax_shifter_tremec_t5t45.php
zebo87
  • Mustang: 87 gt
« Reply #4 on: March 10, 2008, 05:52:38 AM »
i wasnt thinking but i have a b m short throw so i wasnt sure if he had those screws or not.
roushben
  • Mustang: 2000 Roush Stage II
« Reply #5 on: August 05, 2009, 10:18:01 AM »
i have a short throw shifter and i have alot of transmission problems its not the end all be all of tranmission problems
