  • November 19, 2008, 04:37:17 PM *
  • Welcome, Guest
girl mustang white
Girl and 1969 Mach1 Mustang
2007 Ford Mustang GT 520
Big Red
1967 Mustang fastback rear view
Author Topic: Runability problems  (Read 1101 times)
hogieman
  • Mustang: 1966
  • Daily driver: Ford, F150 2005
Runability problems
« on: June 20, 2008, 11:56:28 AM »
I have a 1966 Mustang Convertible Restomod, with a 1992 5.0 rebuilt(2/07) .030 stock piston, stock heads, mild erson cam, 65mm throttle body, A9p computer, rebuilt AOD with shift kit and b&M torque master 2400 stahl, 150lph fuel pump, cobra intake, 19# injectors, 1 5/8" headers, stock distributor, ford racing coil, ford fuel injection wriing harness, 8" 380 posi.
The car starts and idles fine, runs up to 3000 rpm and it starts sputtering and back fires, I have changed computers, distributors, modules, wiring harness. I have checked timing and tried advancing timing with no luck, it seems as if the distributor starts to retard as the engine rpms climb. HELP!!!
    • WWW
Re: Runability problems
« Reply #1 on: June 20, 2008, 04:57:19 PM »
have you checked your tps settings? how about cleaning the maf sensor? is you spout connector hooked into the dizzy wiring? what about 02s?   have you scanned the computer?
 i was having a problem like this after rain its was the cap,rotor,plugs and wires they were all the original parts from 91
hogieman
  • Mustang: 1966
« Reply #2 on: June 20, 2008, 09:06:03 PM »
Checked tps settings they were with in tolerances, new cap, rotor, wires, plugs, spout plugged in, cleaned maf sensor, but I did not disconnect the battery afterwards. I put another ground wire going from the distributor ground to the engine block and to the coil, I also cleaned the coil ground, it got better 4500 rpm's before it started cutting out. I will disconnect battery tonight and re-check timing tomorrow.
« Reply #3 on: June 26, 2008, 04:44:06 AM »
Yeah, anytime you make changes, you need to disconnect the battery to reset the puter.
hogieman
  • Mustang: 1966
« Reply #4 on: July 25, 2008, 11:19:13 AM »
I figured out my problem, I had the wire that goes to the starter solenoid on the wrong side of the solenoid, runs great now, it had voltage but would drop out at higher rpms.
    • WWW
« Reply #5 on: July 25, 2008, 02:32:20 PM »
 ;D  great now it smooth sailing
elderbrock carb problems...
by asko
Electrical problems
Electrical discussions
86cobra 1 5367 Last post January 30, 2006, 02:43:16 PM
by Thierry
1996 sohc-pats key problems
4.6 Mustang technical forum
deaner96 1 3014 Last post January 29, 2007, 08:01:29 PM
by Thierry
Fan and A/C problems
Gene Salisbury 2 2710 Last post March 26, 2007, 07:18:13 AM
by Gene Salisbury
Problems with 1991 Mustang GT
5.0 Mustang technical forum
wmsoccer28 2 3106 Last post February 04, 2008, 09:34:12 PM
by xnutt
Transmission problems please help!
kakarotto05 4 1556 Last post March 10, 2008, 05:52:38 AM
by rabidwolverine
94 GT problems
cbassett1 7 2367 Last post August 12, 2008, 08:49:19 PM
C4 Trans problems
srvblues 2 502 Last post July 08, 2008, 10:21:59 PM
by rmodel65
Mustang problems!?
Mustang Discussions
anrace 2 384 Last post September 20, 2008, 01:00:57 AM
by airwaves
