Author Topic: replacing starter selenoid  (Read 7560 times)
Snipes
  • Gender: Female
  • Mustang: 1990 GT
« on: January 29, 2008, 05:02:10 PM »
Is it fairly easy to replace the starter selenoid? I have a 90' 5.0
  • Administrator
    • Used cars
  • Daily driver: Sunfire
Re: replacing starter selenoid
« Reply #1 on: January 29, 2008, 05:32:05 PM »
If you can lay down under the car, there should be no problem. You can read more about it here but if you have any question, let us know.
Snipes
  • Gender: Female
  • Mustang: 1990 GT
« Reply #2 on: January 29, 2008, 05:38:21 PM »
Thanks...
so I have to take the starter off to do this?
  • Administrator
    • Used cars
« Reply #3 on: January 29, 2008, 07:18:19 PM »
This is the location of the solenoid on the starter for a 5.0 Mustang. I think it would be easier to remove the entire assembly  :)
Bossnutt
  • Gender: Female
    • My Mustang Site
  • Mustang: 1985 Project car
« Reply #4 on: January 29, 2008, 10:12:37 PM »
[quote Snipes]
[/quote]
It's ALOTeasier if you take off the starter to do it.  Otherwise you can't really get to the necessary bolts/ screws.
« Reply #5 on: February 02, 2008, 12:33:22 AM »
Let's just make sure we are talking about the solenoid that is attached to the starter called the starter solenoid, or are we talking about the starter switch which is not attached to the starter?  If it is the solenoid attached to the starter, then that comes with a rebuilt starter, and they are inseperable unless you are real brave to make that move.  You would be silly to try to replace the solenoid that is attached to the starter without replacing the entire starter.
Last post February 03, 2008, 10:49:49 AM
by Thierry
Last post September 03, 2008, 10:47:56 PM
by 66GTKFB
Last post February 20, 2009, 01:39:45 PM
by macstang2
Last post May 26, 2009, 09:24:26 PM
Last post October 03, 2009, 01:54:25 PM
by JimC
