Author Topic: power steering trouble  (Read 1969 times)
ror_schach
  • Mustang: 1993 GT
« on: March 03, 2010, 11:41:27 PM »
my 93 gt has power steering but it doesn't feel like it does at all. its hard to turn the wheel unless you get it rolling. think i need a new pump?
ol dirty doug
  • Ol' Dirty Doug
Re: power steering trouble
« Reply #1 on: March 04, 2010, 12:24:06 AM »
if you have fluid in it and it still is hard to turn then most likely it is bad but there could be a problem with the power rack and pinion?
« Reply #2 on: March 04, 2010, 01:35:42 AM »
It's most likely the pump.  Just be sure you bleed it properly.  I had to replace the rack and pinion on my Mach, but that was a case of a broken seal.  If the rack is not leaking, then you most lilkely have a bad pump.
ror_schach
  • Mustang: 1993 GT
« Reply #3 on: March 06, 2010, 06:46:54 PM »
it was the pump. had some problems at first. had to bleed it a few times. but it turns easy now.
« Reply #4 on: March 06, 2010, 06:57:06 PM »
Good.  It's always good news when we fix our Mustangs.
ror_schach
  • Mustang: 1993 GT
« Reply #5 on: May 08, 2010, 03:37:48 PM »
Still having trouble with the power steering.  got a very fast leak coming from the rack and pinion boot on the driver side. leaking out from around the clamp. just need some advice i guess. should i get a new boot? if so whats involved with installing it. never had this kind of problem before, but i want to try to fix it myself. sometimes thats cheaper... sometimes...... anybody help me out please, send me a link to a guide or something, thanks.
« Reply #6 on: May 08, 2010, 04:30:13 PM »
I would take it to a specialist as I said in an earlier post.
Jaime_302
  • Mustang: 1990 ford mustang gt
  • Daily driver: not yet its under construction
« Reply #7 on: May 26, 2010, 12:04:47 PM »
Dam replace it as what Soaring said.. i had that problem on my old wrk truck..
Last post June 17, 2009, 09:57:58 AM
by mustangluver
Last post June 02, 2009, 11:02:36 AM
by Lanefair
Last post October 04, 2009, 02:53:03 PM
by Lanefair
Last post January 30, 2009, 06:21:25 PM
by 66GTKFB
Last post December 02, 2011, 08:08:22 PM
by Jeff1967
