Author Topic: parts interchange?  (Read 5234 times)
5.0gt
  • Mustang: 1988 mustang gt
  • Daily driver: the mustang and my 1987 F350 diesel
parts interchange?
« on: August 14, 2008, 08:24:09 PM »
i have the chance to buy a 95 mustang with a 5.0 ond 5 speed that was wrecked, can onyone tell me what parts will inter change with my 88 gt with 5.0 and 5 speed, i no the body is different but what about drive train parts?
Re: parts interchange?
« Reply #1 on: August 16, 2008, 11:04:44 AM »
the motor is identical pretty much besides the upper intake the timing cover harmonic balancer and the distributor. all of these parts can be swapped off of your old motor. the transmission can also be used if you swap in the input shaft and the bellhousing from the 86-93 body 5speed
also the electric fan can be adapted and the 130amp alternator as an upgrade. the alt will be a huge upgrade in the entire electrical system of the car and well worth it
5.0gt
« Reply #2 on: August 16, 2008, 12:16:35 PM »
ok thanks i also read this car will donate all parts for 5 lug swap i pic it up monday thanks for the help
« Reply #3 on: August 16, 2008, 02:01:42 PM »
yes it will personally id just swap the entire rear end instead of removing 2 set of brakes also take not it will widen the track of the car  http://www.sn95brakes.com/sn95brakes.php
id get the car and sell all the rest of it
im interested in the ccrm that bolts to the radiator if it is in working shape
5.0gt
« Reply #4 on: August 16, 2008, 03:24:09 PM »
what is that? if ya can get me a pic i'll check the part and let ya know if its good
« Reply #5 on: August 16, 2008, 03:53:47 PM »
it bolts on the radiator it has a bunch of wires going into it. it controls the fan coming on etc
mine works except for the fan function. it is inbetween the radiator and the motor ill see if i can get a pic
5.0gt
« Reply #6 on: August 19, 2008, 09:21:55 PM »
i got the cars its a 3.8 though not a 5.0 so i donno if the parts the same or not
