August 28, 2008, 11:17:34 PM *
Poll
IDEAS - 0 (0%)
HEARD OF THIS - 0 (0%)
Total Voters: 0
Pages: 1 2 »  All
Author Topic: OIL PRESSURE PROB  (Read 5265 times)
rabidwolverine
Jr. Member
Mustang: 87 gt
Daily driver: 87 gt
rabidwolverine
Jr. Member
Mustang: 87 gt
Daily driver: 87 gt
rabidwolverine
Jr. Member
Mustang: 87 gt
Daily driver: 87 gt
Mustang: 65 fastback modded
Daily driver: 1991 gt vert
rabidwolverine
Jr. Member
Mustang: 87 gt
Daily driver: 87 gt
rabidwolverine
Jr. Member
Mustang: 87 gt
Daily driver: 87 gt
        thanks again, jeremy.
rabidwolverine
Jr. Member
Mustang: 87 gt
Daily driver: 87 gt
rabidwolverine
Jr. Member
Mustang: 87 gt
Daily driver: 87 gt
70-90 ft. lbs.
rabidwolverine
Jr. Member
Mustang: 87 gt
Daily driver: 87 gt
rabidwolverine
Jr. Member
Mustang: 87 gt
Daily driver: 87 gt
Pages: 1 2 »  All
