1965 Restomod
Mustang CS girl
1968 Mustang convertible
Mustang girls car wash
Mustang girls
Poll
  • IDEAS
    - 0 (0%)
    HEARD OF THIS
    - 0 (0%)
Total Members Voted: 0
Pages: 1 2 »  All
Author Topic: OIL PRESSURE PROB  (Read 7098 times)
rabidwolverine
  • Mustang: 87 gt
  • Daily driver: 87 gt
OIL PRESSURE PROB
Re: OIL PRESSURE PROB
rabidwolverine
  • Mustang: 87 gt
rabidwolverine
  • Mustang: 87 gt
    • WWW
rabidwolverine
  • Mustang: 87 gt
    • WWW
rabidwolverine
  • Mustang: 87 gt
        thanks again, jeremy.
rabidwolverine
  • Mustang: 87 gt
rabidwolverine
  • Mustang: 87 gt
70-90 ft. lbs.
rabidwolverine
  • Mustang: 87 gt
rabidwolverine
  • Mustang: 87 gt
    • WWW
Pages: 1 2 »  All
Oil pressure
5.0 Mustang technical forum
FASTSTHANG 9 5978 Last post October 22, 2006, 07:08:50 PM
by FASTSTHANG
