Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Contact
Login
Register
Forum
Technical forums
5.0 Mustang technical forum
Topic:
OIL PRESSURE PROB
Pages:
1
2
Go Down
Author
Topic: OIL PRESSURE PROB (Read 13219 times)
zebo87
Sr. Member
Gender:
Mustang: 87 gt
Daily driver: 87 gt
OIL PRESSURE PROB
on:
March 02, 2008, 03:38:24 PM »
Gender:
Re: OIL PRESSURE PROB
Reply #1 on:
March 02, 2008, 03:50:57 PM »
I'm confused. Is this an oil "Pressure" problem, or an oil "leak" problem? If you are concerned about the leak under your intake, then just simply take the intake off and replace the gasket.
zebo87
Sr. Member
Gender:
Mustang: 87 gt
Daily driver: 87 gt
Reply #2 on:
March 02, 2008, 05:02:21 PM »
Gender:
Reply #3 on:
March 02, 2008, 05:18:41 PM »
Yeah, you just need to get that gasket replaced. Of course it is going to leak more at higher pressure. Be sure you download a correct torque guide so you get those bolts torqued just right and in the right sequence, then you won't have future problems. I have those torque specs in the FAQ section on the classic board.
zebo87
Sr. Member
Gender:
Mustang: 87 gt
Daily driver: 87 gt
Reply #4 on:
March 02, 2008, 05:26:24 PM »
Gender:
the mustang man
Mustang: 65 fastback modded
Daily driver: 1991 gt vert
Reply #5 on:
March 05, 2008, 02:32:46 AM »
zebo87
Sr. Member
Gender:
Mustang: 87 gt
Daily driver: 87 gt
Reply #6 on:
March 05, 2008, 06:48:01 AM »
Gender:
Reply #7 on:
March 05, 2008, 07:08:26 AM »
Then you're on the right track by replacing the gasket. Be sure you use blue RTV in the corners.
Gender:
the mustang man
Reply #8 on:
March 05, 2008, 11:30:48 AM »
Gender:
Reply #9 on:
March 05, 2008, 12:29:51 PM »
zebo87
Sr. Member
Gender:
Mustang: 87 gt
Daily driver: 87 gt
Reply #10 on:
March 05, 2008, 03:36:02 PM »
thanks again, jeremy.
Gender:
Reply #11 on:
March 06, 2008, 06:28:03 PM »
Between me, Stephen and Jim, we can take that engine apart and put it back together in the dark blindfolded. Get back here if you have more questions or run into a snag. If you are on any other forums and have friends there, ask them in a PM to come visit here and enjoy friendly classic Mustang discussion.
zebo87
Sr. Member
Gender:
Mustang: 87 gt
Daily driver: 87 gt
Reply #12 on:
March 06, 2008, 06:53:53 PM »
zebo87
Sr. Member
Gender:
Mustang: 87 gt
Daily driver: 87 gt
Reply #13 on:
March 22, 2008, 10:13:24 AM »
Gender:
Reply #14 on:
March 22, 2008, 06:29:42 PM »
70-90 ft. lbs.
zebo87
Sr. Member
Gender:
Mustang: 87 gt
Daily driver: 87 gt
Reply #15 on:
April 01, 2008, 05:19:09 PM »
Gender:
Reply #16 on:
April 01, 2008, 10:17:14 PM »
Don't get frustrated, that's when you start fuckin up. I sounds like you need to check you spark plug wire routing. Tell me what your wiring routing is. If you don't know, and don't know how to check it , get back. If it smokes and sounds like it is missing and doesn't have much power, then that is your problem.
zebo87
Sr. Member
Gender:
Mustang: 87 gt
Daily driver: 87 gt
Reply #17 on:
April 02, 2008, 05:57:55 AM »
Gender:
Reply #18 on:
April 02, 2008, 07:38:45 AM »
Besides timing it, you might want to check the gap on a few plugs to make sure they are close. Also check and reset your points if you still have them. The best advice I can give you about points is to throw them as far as you can and put in an electronic ignition system. Pertronix is the cheapest way to go, and works very well.
Gender:
the mustang man
Reply #19 on:
April 03, 2008, 12:38:36 AM »
did you set the timing with a light and the spout disconnected? if not you need to remove the spout and then start the car 10beg btdc is stock but you can go higher i run about 12deg in my 5.0 but if you go higher then you need to run mid grade or premium also. but there will be an increase in gas mileage that will offset the additional cost.
Pages:
1
2
Go Up
Forum
Technical forums
Topic:
OIL PRESSURE PROB
Navigation
Used Cars for sale
Ford Mustang classifieds
Powered by
EzPortal
