Author Topic: need help i have a 95 351w motor efi and i want to know should i run efi or carb  (Read 2536 times)
knockemstiff
  • Mustang: 89 gt/64 1/2 convertable
  • Daily driver: 99 gmc burban
and if i run efi i don't have wire harness or putur what is the pros vs cons to carborator or efi help me out here also canyou turbo a carb motor??? see i need some help e mail or just postyour responce please need info ;)
Where's this engine going?
knockemstiff
89gt street & strip car
ol dirty doug
  • Ol' Dirty Doug
fuel inject it! you can get all the 5.0 stuff for it for cheap on ebay!
knockemstiff
ok how do i run it with out the wire harness and puter and what can you do to the stock efi to get more out of it.based on a c4 with stall and 410 gears and gt 40 heads to go on the 351 w what would be some ideas to get the most for my buck
Yes, you can turbo charge a carbuteted engine, but all I would do would be to keep the EFI and add a cold air intake.  It just depends on what you are going to use the car for.
ol dirty doug
  • Ol' Dirty Doug
you can do almost anything with it! if you do the 89-93 comp and harness you can do all the same stuff to it as the 5.0 except you have a larger displacment engine. (so you would be a step up)  its all compatable the 5.0 and 351 are the same except for deck height, so that means that anything you can bolt on to the stoock 5.0 will bolt to the 351. (intake manifold being the only difference)
