Author Topic: My 1990 ford mustang 5.0 lx turn signal problems..?  (Read 6786 times)
knocar
« on: September 20, 2008, 05:19:30 AM »
OKay, so when i hit the switch my turn signals wont work, neither left or right... But my hazards do work...Checked the fuse and bulbs and everything is fine..what can it be?
zebo87
  • Mustang: 87 gt
  • Daily driver: 87 gt
Re: My 1990 ford mustang 5.0 lx turn signal problems..?
« Reply #1 on: September 21, 2008, 01:26:24 PM »
wel im not sure id have to look in my chiltons but it sounds liks a relay or something. let mo look and get back with you.
zebo87
  • Mustang: 87 gt
« Reply #2 on: September 21, 2008, 08:22:44 PM »
ok there is one multi function switch that controls those so you should check that out. the switch is behind the steering column cover so you will have to remove it. before you replace it you can just check the output to the siganls with a fluke. i hope that helps.
« Reply #3 on: September 22, 2008, 06:34:18 PM »
the turn signal switch is the multi function switch he is talking about, swithc it and you should be good to go
kevinlvy
  • Mustang: 1974 mustang II
  • Daily driver: FJ Toyota
« Reply #4 on: February 05, 2011, 12:51:24 AM »
hi guys i am experiencing this one also just took out the signal lens assembly to replace it with the brand new lens repair kit i bought online since it was accidentally hit by a ball by my cousin and now its intermittent and also check the wires and fuses looks ok though..
TheJ
« Reply #5 on: February 05, 2011, 02:48:39 PM »
sounds more like a turn signal relay(flasher) than the switch itself.
« Reply #6 on: May 22, 2011, 11:31:51 PM »
not so much...the hazzards are still working and they are going through the same flasher unit...
TheJ
« Reply #7 on: May 22, 2011, 11:50:11 PM »
The hazards do not use the same unit as the turn signals.  They are two separate relays.  The hazard relay is behind the fuse block and the turn signal relay is behind the center of the dash on a support bracket.
B Gordon
  • Mustang: 95 GT
« Reply #8 on: September 21, 2011, 02:52:40 PM »
I had the same problem...found one wire from the switch was broken, soldered the wire back on the tab and it works fine....are your wipers working ok too?
Last post May 31, 2005, 11:27:23 AM
by Jerry Baker
Last post August 23, 2009, 09:55:04 PM
by bigt8156
Last post January 29, 2010, 06:01:06 PM
by Mr_Nice_Guy
Last post November 22, 2010, 08:30:55 PM
by ffrkitcar
Last post July 29, 2011, 11:53:09 PM
by jonlyjayman
