Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Contact
Login
Register
Forum
Technical forums
5.0 Mustang technical forum
Topic:
Mustangs lights are really dim....
Pages:
1
Go Down
Author
Topic: Mustangs lights are really dim.... (Read 11218 times)
mustanggt5.0
Jr. Member
Gender:
My Stang
Mustang: 1995 Mustang GT 5.0
Daily driver: Mustang is my daily driver.
on:
December 12, 2008, 01:39:54 PM »
The lights on my 1995 mustang gt are really dim... i can barely see at night... and these lights here on the bottom
http://i2.tinypic.com/43cyuk8.jpg
they dont even turn on ever on my car... when are they supposed to turn on and what could be wrong with them? thats not my car by the way.. just a picture that i found on the internet for illustraitional purposes.
Photo contest winner
Daily driver: 1969 VW Baja
Re: Mustangs lights are really dim....
Reply #1 on:
December 12, 2008, 03:06:25 PM »
Those look like parking lights as opposed to fog lights or driving lights, that under normal operation do
not
turn on when the headlights are on. They are also used as turn signal lights and emergency flasher lights. When the car is running, activate the turns signals and emergency flashers and take a look. I think you will find an intermediate position on the headlight switch that will turn on the parking lights.
mustanggt5.0
Jr. Member
Gender:
My Stang
Reply #2 on:
December 12, 2008, 03:45:49 PM »
i tried what you suggested and got nothing... idunno... any other ideas?
Gender:
Reply #3 on:
December 12, 2008, 06:26:25 PM »
For some reason you are not getting full power to your headlights. Check the ground wires from the lamps. Here is a fix that we old classic guys use to brighten our headlights. If all else fails, you might try this. It worked wonders on my 65, and I imagine it will also work on an S195 as well. Also, here is a picture of your 1995 turn signal and parking light, so it is neither one of those. They are not a driving or fog light either. (see third picture of a 1995 driving-fog light) I have run out of ideas. Search around the dash and underneath it for a switch you haven't discovered yet I guess. One last thing. Is your 95 a Cobra? Because that is the only Mustang built in 95 with those little round lights up front. All other mustangs during that year did not have those little round lights. See the pic of a typical 1995 Mustang.
http://midnightdsigns.com/james/headlights.htm
mustanggt5.0
Jr. Member
Gender:
My Stang
Reply #4 on:
December 12, 2008, 07:32:49 PM »
Its a 1995 gt and ya its those fog lights. it looks just like that.
mustanggt5.0
Jr. Member
Gender:
My Stang
Reply #5 on:
December 12, 2008, 07:40:42 PM »
Silly me... it was a switch right next to the e-brake....
Gender:
Reply #6 on:
December 12, 2008, 08:02:39 PM »
OK, then you gave us a picture of another year model Mustang, because a 95 does not have the round lights as you showed except for the Cobra of the year 1995. If it is a GT, then the pic I showed you is what you should have. And, it should work with the turn signals and the emergency lights. Check all your fuses, then get back.
mustanggt5.0
Jr. Member
Gender:
My Stang
Reply #7 on:
December 12, 2008, 08:06:08 PM »
it all looks good,.. and im just gonna switch out the bulbs for some brighter ones... do u have any recommendations for what kind of bulbs i should put?
Gender:
Reply #8 on:
December 12, 2008, 08:16:04 PM »
That model may have come with Halogens, but not sure. The bulb itself will have "halogen" on it. If not, then buy halogen bulbs. However, that 95 model should have very bright headlights, and I fear it is not your bulbs that are the culprit for dim headlights. I would seriously consider cleaning any and all contacts such as the grounds to make sure you are getting a full charge from the electrical system.
mustanggt5.0
Jr. Member
Gender:
My Stang
Reply #9 on:
December 12, 2008, 10:17:03 PM »
hmmm is there a tutorial online that will give me some pictures of what i need to clean? ill try this in the morning then. thanks.
Gender:
Reply #10 on:
December 15, 2008, 07:30:05 PM »
Nah, no tutorial. Use your brain. Take off the headlight bucket or whatever it takes to expose the head light and figure out what is behind there that needs to be cleaned like the ground wire.
Gender:
the mustang man
Mustang: 65 fastback modded
Daily driver: 1991 gt vert
Reply #11 on:
December 18, 2008, 02:16:25 AM »
are you headlight lens yellowed? if so buy some new ones off ebay. as for the fog lights not coming on they probably only work when the headlights are on low. i would check my 95 GT, but is actually a GTS and has fog light deletes
mustanggt5.0
Jr. Member
Gender:
My Stang
Reply #12 on:
December 18, 2008, 02:19:47 AM »
what is a fog light delete?
ive heard of an airbag delete also... what are you talking about when you say delete?
Gender:
the mustang man
Reply #13 on:
December 18, 2008, 02:23:33 AM »
my car isnt a gt, its a GTS it came without a rear spoiler, foglight, maplights has the standard v6 interior. basically its like a LX 5.0 but for the 94-95 bodystyle
http://www.quannet.org/corey/gtsinfo.html
mine is 1 of 1400 in black
poisonivy24
Gender:
Mustang: 2009 Ford Mustang GT/CS convertible
Reply #14 on:
June 17, 2011, 09:28:55 PM »
I have the same problem with my turn signal, I tried to change the bulb but nothing happened. A friend told me that maybe it is the
turn signal switch
or the wiring inside it. I also need a tutorial on how to remove the lights and check the wiring and also how to check if it is the switch that has problem.
Pages:
1
Go Up
Forum
Technical forums
Topic:
Navigation
Used Cars for sale
Ford Mustang classifieds
Powered by
EzPortal
