You will have one heck of a vibration if you don't change the flywheel/flexplate, your original motor is balanced at 28.5ozs the new motor is 50oz. Since you are using the old trans don't bother looking for a used flywheel/flexpate it's an oddball, If I remember right it has 141 teeth on the flexplate and the only place I could find one was at art carr perfomance.
One last suggestion is the cars rear axle if it's stock it is an 8 inch (uses the same parts as a small bearing 9 inch) and it'll have 3.55 gears which is cool, but only one wheel is driven so you'll have to either put in a spool or traction device of your choice. The reason is that you are about to take your traction poor car from 139 stock HP to 225 HP.
