So My car has the 24 lb injectors with the 498 lift cam and a 70 mm throttle body and spacer and its got the upper and lower edelbrock intake. Well its got the stock MAF sensore which is made for the 19 lb injectors so my car is not running like it should be. But what size mm of maf sensor do i need to get? There is the 73 mm maf sensor for the 24 lb injectors and i didnt know if that was to big for my car? its got the 5.0 liter in it. Thanks
