Author Topic: intermittent crank but no start  (Read 1649 times)
ljcollicutt
  • Mustang: 1995 GT convertible
  • Daily driver: 1998 Dodge Dakota
« on: April 11, 2010, 11:05:43 PM »
Hello. New to the forum. 95 GT 5.0L, 5 spd. Runs perfectly when running. Car starts well. Next time, crank but no start. This goes on time and time again making the car unreliable to use as you never know when it will happen or where.Might run for a week,  a day, an hour without this happening again. When it does this, may start after an hour or less sitting or it may not but it eventually starts. At my wits end as are the mechanics. New fuel pump, distributor. Local mechanics cannot isolate the prob it seems. Thought someone here may be able to help. Not a mechanic with limited mechanical knowledge. Mechanic says every thing checked including codes, injectors ,spark. All seems fine. Thanks for any help.
Re: intermittent crank but no start
« Reply #1 on: April 11, 2010, 11:30:49 PM »
Most likely a grounding problem. Clean all the grounding wires.  Welcome to the site.
ljcollicutt
« Reply #2 on: April 12, 2010, 09:50:28 AM »
Thank you. I WILL try that !! [attachthumb=1]
mustang245
« Reply #3 on: April 12, 2010, 10:40:57 PM »
Soarings right. It sounds like your ground connections are making proper contact. Trying cleaning the grounds and check the connections just to be sure that nothing is loose
