Author Topic: im getting code 95  (Read 3164 times)
ballajb
  • Mustang: 1964 1/2 Mustang
  • Daily driver: 2004 CLK
im getting code 95
« on: March 17, 2010, 11:10:31 AM »
I am getting code 95 when I am running the codes on my mustang. Code 95 list as "fuel pump secondary circuit fault". What can I do to fix this?
Re: im getting code 95
« Reply #1 on: March 17, 2010, 03:19:11 PM »
Check the fuel pump relay on it,the pump relay is considered to be the secondary circuit, and is located under the hood, and is a small black plastic box.
ballajb
« Reply #2 on: March 17, 2010, 03:24:18 PM »
ok thanks, i will check out the relay and possibly replace it
mustang245
« Reply #3 on: March 18, 2010, 02:10:55 PM »
Checking the relay is a good idea, and to be safe i would also check the wires for any damage.
ballajb
« Reply #4 on: March 23, 2010, 11:09:17 AM »
Thanks to everybody who helped me with coming out with things to check, but i got the car working fine now. I ended up being a wire that went to my starter solenoid that was on the wrong post. I called the tech support of the maker of my efi  swap harness and told me a wire that went to my starter solenoid needed to be on a post that only was hot when the key was in crank position and i had it on a post that was hot all the time. So now for a tune, does anyone know of any good places in the bay area?
« Reply #5 on: March 23, 2010, 01:12:46 PM »
Yeah, a wire on the wrong post will cause that.  How in hell did you get a wire on the wrong post?   ;D  I live in Texas, but maybe Jim Curylo can help you.  He lives in the land of the fruits and nuts, and is not too far from the SF area.
ballajb
« Reply #6 on: March 23, 2010, 01:16:16 PM »
lol, the instructions for the harness just said to put it onto the start solenoid but did not say anything about when the wire needed to be hot. So i just connected it to one of the post not knowing the wire only needed power in the crank position
« Reply #7 on: March 23, 2010, 01:18:30 PM »
Live and learn.  Glad you got her fixed.
code 95
code 95
« Reply #8 on: June 21, 2011, 10:36:03 AM »
Yes im also glad you fixed the code 95 problem, it took me almost 2 weeks to figger out how to solve it. So you did a realy good job!
ballajb
« Reply #9 on: June 21, 2011, 10:41:30 AM »
Thanks
