Author Topic: having trouble with my lights  (Read 1180 times)
ror_schach
  • Mustang: 1993 GT
« on: March 03, 2010, 07:59:32 PM »
headlights get dimmer when i turn on the brights. the left side turn signal turns on but doesn't flash.  the right side turn signal flashes extremely fast. any ideas?
Re: having trouble with my lights
« Reply #1 on: March 04, 2010, 12:31:06 AM »
Sounds like grounding problems to me.  You need to clean all the wiring grounds so they make good contact.  Also, change the bulbs to new ones and use your pocket knife to scrape the lead contacts so they make good contact.
ror_schach
  • Mustang: 1993 GT
« Reply #2 on: June 26, 2010, 11:31:50 PM »
so i got new headlight bulbs, that fixed my dim problem. but i've discovered that the wiring has been tampered with. for some reason somebody wired the turn signals and parking lights together. can i buy a new wiring harness for all the lights? or can somebody help me find a wiring diagram that might get things back right? i'd really appreciate it. i hate riding around with no signals.
« Reply #3 on: June 27, 2010, 03:28:49 PM »
a junkyard will be your best bet...the harness is the same for gt and lx model if i remember correctly so you can just take the harness from say a 4cylinder car and run with it.
the GT car have problems with their fog lights it is a big strain on the headlight switch and the turn signal switch a lot of people install headlight and fog light relays to fix this problem
ror_schach
  • Mustang: 1993 GT
« Reply #4 on: June 28, 2010, 01:47:58 AM »
i'm suppose to have fog lights on my car but they're missing. and the wires have all been spliced. i did find a wiring diagram to rewire the headlights so they don't overload the switch. but that doesn't help me solve the turn signal problem. i replaced my flasher. nothing works right in the front except my headlights. my hazards work fine in the rear. but if i turn on the turn signal the light just stays on, it doesn't flash. could it be a faulty switch? or could it have something to do with the wires up front?
« Reply #5 on: June 28, 2010, 01:22:51 PM »
You've got to get those wires squared away before you try anything else, but it could be the flasher unit itself.  Also, make sure the turn signal bulbs are new and making good contact.  Go to Google and search for a wiring diagram for your year model.
All I have are for the classics.
Last post February 12, 2009, 02:44:37 AM
by stang thang
Last post February 06, 2010, 03:48:35 PM
by jmanion
Last post May 26, 2010, 12:04:47 PM
by Jaime_302
Last post March 31, 2010, 12:47:40 PM
by TexasAxMan
Last post May 02, 2010, 04:37:56 PM
by my0wn3ds
