Author Topic: Error codes  (Read 1254 times)
ballajb
  • Mustang: 1964 1/2 Mustang
  • Daily driver: 2004 CLK
Error codes
« on: March 15, 2010, 01:05:15 PM »
Right now I am having problems with my car... Right now i can not go over 3500 rpms... When i reach that it starts to tach out... I ran my codes with the key in the on position and 81,82,85,84,22,33 and 95 came up. I also ran the codes with the car running and 33,94 and 44 came up. I know some of these are smog codes and i am running long tube headers but for the others, what are the specifics that i need to do to get these to go away?
Re: Error codes
« Reply #1 on: March 15, 2010, 01:10:02 PM »
OK, let's start by identifying which car you are talking about.  The 64 1/2 Mustang didn't have a computer, unless you altered it.
ballajb
Re: Error codes
« Reply #2 on: March 15, 2010, 01:18:14 PM »
that is correct but i did a efi swap in it. So i now have a computer... I put a motor from a 1991 5.0. I did a head and cam swap (f303 cam) long tube headers, typhoon upper and lower intake, msd dizzy,coil and 6AL box.
zebo87
  • Mustang: 87 gt
  • Daily driver: 87 gt
Re: Error codes
« Reply #3 on: March 17, 2010, 06:48:48 PM »
i was having this same prob. try cleaning your maf.
Re: Error codes
« Reply #4 on: March 17, 2010, 08:58:19 PM »
Yeah, most everytime you have a missing problem with those EFI's it goes back to a dirty MAF.  That is a part of the maintenance you have to do everytime you change the oil and filter.   I have a K&N air filter on my 03 Mach, and whenever I clean the K&N, I also clean the  MAF.  Works for me.
ballajb
Re: Error codes
« Reply #5 on: March 23, 2010, 11:37:21 AM »
Thanks to everybody who helped me with coming out with things to check, but i got the car working fine now. I ended up being a wire that went to my starter solenoid that was on the wrong post. I called the tech support of the maker of my efi  swap harness and told me a wire that went to my starter solenoid needed to be on a post that only was hot when the key was in crank position and i had it on a post that was hot all the time. So now for a tune, does anyone know of any good places in the bay area?
Last post April 04, 2009, 11:14:26 AM
by gvt60
Last post April 04, 2009, 04:21:24 PM
Last post March 01, 2010, 08:53:16 PM
by viperrick93
Last post January 15, 2010, 04:35:50 PM
by lil_hulk
Last post January 22, 2010, 05:39:55 AM
by zebo87
