Author Topic: c4 shifting issue  (Read 1696 times)
79pace
  • Mustang: 79 5.0 pace car
  • Daily driver: 95 ford f 150 ext cab 4x4
c4 shifting issue
« on: March 01, 2010, 08:16:26 PM »
I just bought a 79 pace car some one took out the turbo and put a c4 with a 302 in it. When you take off you have to shift it manually when it hits 3rd gear you have to back off the throttle a little it will then shift in to 3rd if you dont it slips. When you get it in 3rd it will not slip at all. Is their a good starting point to check? It has vac. line hooked up to the holly carb and the linkage is hooked to trans. Any help would be great. Thanks
Re: c4 shifting issue
« Reply #1 on: March 01, 2010, 09:59:19 PM »
Welcome to the site.  I don't know what you are talking about, but you may have a tranny with a limited slip, or it has some altercatiion that keeps it in 2nd until you manually shift it to third.  The C-4 only has three foreward gears.
79pace
« Reply #2 on: March 02, 2010, 09:53:53 PM »
What would i have to change to put a AOD pre 91 trans in it? Would the drive shaft length be the same?
