Author Topic: blowing fuse  (Read 5164 times)
Guest
  • Guest
blowing fuse
« on: May 31, 2007, 12:06:43 PM »
Hi, I own a 93 Mustang GT with 33,000 original miles. I keep blowing a fuse that controls the turn signals, foglamps, reverse lights, and rear defrost. It happens everytime I turn the key to the on possition. Obviosly I have a short but I don't know where to begin. Can anyone help? Best reguards, Geno
  • Administrator
    • Used cars
  • Daily driver: Sunfire
Re: blowing fuse
« Reply #1 on: May 31, 2007, 01:25:27 PM »
You will have to proceed by elimination. If you know what the fuse controls it's a good start.
You can try to turn off or disconnect all the elements the fuse is controlling. If the fuse still blows, I don't know what to tell you. If it doesn't, you can connect one at a time to until the short happens again. You should then be able to tell where is the problem and it should be easier for you to locate a loose or damage wire or connection.
Guest
  • Guest
Re: blowing fuse
« Reply #2 on: June 01, 2007, 07:44:29 AM »
Thanks, I will start disconnecting one at a time and see what happens. I will keep you updated. Geno
