Author Topic: Adjustable crane rocker arm problems  (Read 1853 times)
ballajb
  • Mustang: 1964 1/2 Mustang
  • Daily driver: 2004 CLK
« on: November 02, 2009, 11:28:30 AM »
Ok i am having a problem. I started my car and noticed a ticking noise under the valve cover. So i took it off and noticed that 2 of my rockers had came off/loosened. I tried tightening them and started the car and the same 2 did the same thing again. I am wonderin what could this be? Why are they coming a loose? i am using the locks and everything. Could it be that i need to clean them off and let them dry before i try again? could it be that the oil that are in the grooves now from the nut and lock coming off?
Has anyone else ever had this problem? if so how did you fix it?
Re: Adjustable crane rocker arm problems
« Reply #1 on: November 02, 2009, 06:18:25 PM »
Are you letting the rods relax (fall back down) before tightening?
ballajb
« Reply #2 on: November 02, 2009, 06:24:36 PM »
maybe thats what i need to do. turn the motor over untill they are both flat and even correct? and then tighten them back
« Reply #3 on: November 02, 2009, 07:16:22 PM »
Yup!
ballajb
« Reply #4 on: November 03, 2009, 11:36:12 AM »
Ok, so i checked again yesterday and what i found is a lot of my studs were not as tight as they could be. So i basically tighted all of them and reset all the rockers... Put everything back on and its fine... Finally after taking things apart a couple of times. Now just to figure out how to stop this whistling noise from my throttle body....
Thanks for the help everyone
Last post June 18, 2009, 04:46:37 PM
Last post June 28, 2009, 11:38:06 PM
by pasternak3166
Last post December 15, 2009, 02:17:24 AM
Last post January 11, 2010, 09:08:48 PM
by djg3582
Last post February 15, 2011, 03:41:20 PM
by Snake-Eater
