1969 Mustang 302
1972 Mach 1
100 0793
MUSTANG 1989 GT
302ci. some mods
Author Topic: 94 GT problems  (Read 2433 times)
cbassett1
94 GT problems
« on: May 14, 2008, 06:37:08 PM »
I have a 1994 mustang GT 5.0 manual trans. that will sputter when it hot or cold and when we press down on the gas fully then we receive minimal power(slow rise in rpms) until we get to approx. 2000 rpms in which we will not get any more power.  However we can still gain speed or get power above if we are lightly touching the gas.  The current gear is not the problem.  We can be on a 15 degree grade uphill and still be slowing down(not very fast but still slowing down)with the gas at full throttle but with just a little bit of throttle, we will get better response.  Basically, on level or uphill grade, with the throttle at full we have extremely little power/response. but with very minimal throttle we get more power/response.  Our beliefs is that it is the calytic converter.
    • WWW
Re: 94 GT problems
« Reply #1 on: May 14, 2008, 08:32:45 PM »
cats might be a problem, try pulling the O2's out and start it up see if it runs better.
also try unplugging the mass air meter see if it runs better, if it does remove the 2 screws and clean the element with some maf cleaner and a q tip
also check the readings on the tps sensor
cbassett1
Re: 94 GT problems
« Reply #2 on: May 22, 2008, 12:22:55 AM »
Our cats are getting hot enough to start turning red and will singe pinestraw that is under them.  Does anyone know the approx. standard temp of the cats?
    • WWW
Re: 94 GT problems
« Reply #3 on: May 26, 2008, 12:44:04 AM »
if they are glowing they are definitely bad, you can go for an off road h-pipe(cheapest route if you dont have to pass a smog test) or you can pony up the extra cash and buy a new h pipe with high flow cats, or pick up a junkyard unit good place for used parts is http://www.mpssalvage.com they are the largest late model mustang dismantler i have used them before with good luck :)
cbassett1
Re: 94 GT problems
« Reply #4 on: May 28, 2008, 10:32:28 PM »
Also it blows out black smoke when we hit the gas even lightly pressing it.  It does not blow out a big cloud, but only just enough to notice it.  Could it be related to my problems(cats,O2 sensors, etc.?)  What could be its problem?  In my opinion this car did like most fords do, they work mostly well then all at once "everything" goes wrong.
    • WWW
Re: 94 GT problems
« Reply #5 on: May 29, 2008, 01:37:20 AM »
sounds like the maf sensor to me. but it could be the o2s
taxicab
  • Mustang: 1994 gt
  • Daily driver: 1994 mustang gt
Re: 94 GT problems
« Reply #6 on: August 12, 2008, 08:03:36 PM »
A tech told me that black smoke upon hitting the gas is a sign of bad or worn valve seats. Dont know if there is much truth in it, but it could be an issue.
Re: 94 GT problems
« Reply #7 on: August 12, 2008, 08:49:19 PM »
Your tech is wrong.  Black smoke indicates you are running too rich of a fuel/air ratio. Blue smoke indicates you are  burning oil and white smoke means you are buring water, meaning you have a blown head gasket.  If it is black and not blue, then you need a general tune-up to get that fuel/air ratio correct.  The MAF may be dirty, so after cleaning it you still have the problem, then take it to a Ford dealer for a check to see if you need a tune-up.
Electrical problems
Electrical discussions
86cobra 1 5410 Last post January 30, 2006, 02:43:16 PM
by Thierry
1996 sohc-pats key problems
4.6 Mustang technical forum
deaner96 1 3055 Last post January 29, 2007, 08:01:29 PM
by Thierry
Fan and A/C problems
Gene Salisbury 2 2748 Last post March 26, 2007, 07:18:13 AM
by Gene Salisbury
Transmission problems please help!
5.0 Mustang technical forum
kakarotto05 4 1602 Last post March 10, 2008, 05:52:38 AM
by rabidwolverine
Distributor Problems - Seeking Advice
AJ Zurn 4 1197 Last post May 10, 2008, 02:02:39 PM
Runability problems
hogieman 5 1157 Last post July 25, 2008, 02:32:20 PM
by rmodel65
C4 Trans problems
srvblues 2 540 Last post July 08, 2008, 10:21:59 PM
by rmodel65
Mustang problems!?
Mustang Discussions
anrace 2 421 Last post September 20, 2008, 01:00:57 AM
by airwaves
'66 coupe tail lights problems
Mitchjd2 0 130 Last post October 29, 2008, 01:43:24 PM
by Mitchjd2
starting problems
johnnyredneck 1 39 Last post November 30, 2008, 09:32:03 PM
