if they are glowing they are definitely bad, you can go for an off road h-pipe(cheapest route if you dont have to pass a smog test) or you can pony up the extra cash and buy a new h pipe with high flow cats, or pick up a junkyard unit good place for used parts is
http://www.mpssalvage.com they are the largest late model mustang dismantler i have used them before with good luck
