Author Topic: 91 lincoln mk vii caliper upgrade  (Read 5203 times)
slovert
  • Mustang: 89 lx vert
« on: August 23, 2008, 11:58:24 AM »
hi-- newb here- i just upgraded my 89 lx vert w/lincoln mk vii calipers(reman) w/hawk hps shoes. i kept the rotors stock for now. the calipers have some side play- there is some vibration under light brake pressure. anyone have the same upgrade or problem i'm having.thought about sending these back and ask for another set of calipers-- what do you think-  thanks.
Re: 91 lincoln mk vii caliper upgrade
« Reply #1 on: August 23, 2008, 03:26:22 PM »
Were you sure the calipers would mate up with the other stock stuff before getting them?  If so, and they are not right, I would take them back for a refund and get the right ones.
« Reply #2 on: August 24, 2008, 12:44:12 AM »
I imagine you need to check the run out on the rotors they are probably warped slightly.
The mark7 upgrade is a common upgrade on the fox mustang.  Basically when you add the Lincoln caliper you have the SVO mustang style setup.
Normally with the caliper upgrade, you do an m/c upgrade also to keep the pedal nice and firm
info: http://mjbobbitt.home.comcast.net/~mjbobbitt/mustang/4lug.html
