1971 Mach 1
Girl Mustang
1966 Fastback
2006 gt convertable
1969 Mach 1
Author Topic: 88 mustang stalls in heat  (Read 1072 times)
roldy
« on: May 22, 2008, 05:02:20 PM »
I have a 8 cylinder 88 gt mustang and a problem that i can't seem to find what the cause is. Every so often whenever it is hot out my car dies. After waiting a good 30-45 minutes, it'll start up. I've read on some forums about the TFI module not working when it gets hot. I relocated it to a place where it gets some air flow instead of it sitting on the hot engine. I have an MSD ignition module with MSD coil. The MSD ignition module is located underneath the dash on the passenger. What could be the problem here?
Re: 88 mustang stalls in heat
« Reply #1 on: May 22, 2008, 06:07:48 PM »
First off, you double posted, so I removed one of them.  Not a problem...it happens all the time.  On your stalling when she gets hot, it sounds like a classic case of vapor lock.  That's when the gas in the line or carb gets so hot that it turns into vapor so won't burn.  Since 1988 was the first year for Ford to use fuel injection instead of a carburetor, I don't know what to tell you about keeping heat away from the EFI, but double check your fuel lines to make sure they are not near the exhaust manifolds.  The guys with the 5.0's will be along here sooner or later so hang tight.
    • WWW
« Reply #2 on: May 26, 2008, 12:39:31 AM »
you say you relocated the tfi(thick film ignition module) but did you replace it? if not my bet is that it is still bad. they arent  to expensive about $45 id put my money on the tfi hands down
roldy
« Reply #3 on: June 03, 2008, 06:46:46 PM »
Sorry about the long over due reply. I did replace the tfi with a new one. I took the car to a shop and they said to replace the ignition coil because it was leaking it's oil (I now have a msd blaster 3) and also replaced the tfi (which is now located back on the distributor). Even though I hear my fuel pump working, could it still be causing vapor lock? I looked for pinched lines and sharp bends. Fixed one line but still have a problem. I'll take pics of my engine bay so you can see where the lines are. Also, could old cats be a problem when they get hot?
Your Mustang
Your Mustangs
Jerry Baker 57 34129 Last post June 21, 2008, 08:32:06 PM
by Thierry
67 Mustang
Mustang Discussions
dacummings 1 12435 Last post June 22, 2005, 08:22:34 PM
by Thierry
first mustang
matt23 6 9726 Last post August 17, 2005, 04:47:14 PM
by matt23
73 mustang
Mustang Discussions
Guest 3 6635 Last post March 09, 2006, 08:03:10 PM
by Thierry
64 1/2 mustang
Mustang Discussions
carols 1 4711 Last post March 11, 2006, 09:38:44 AM
by Thierry
70 Mustang Pic
Mustang Discussions
Jerry Baker 3 4624 Last post April 04, 2006, 10:12:06 PM
by Russ
Roush Mustang vs Saleen Mustang
Racing videos
Thierry 0 2502 Last post November 27, 2007, 12:50:16 PM
by Thierry
1980 Ford Mustang Mustang Ad
Mustang commercials
Thierry 0 987 Last post November 27, 2007, 01:25:00 PM
by Thierry
Heat from engine into interior from vents
Mustang Discussions
Angelo R 3 391 Last post September 23, 2008, 07:26:17 AM
by crzylx
