Looking at putting a 302 stroked to 347 in my 84 stang.
Uses: Strip and Street. Mostly Strip. Looking at around 400-450 HP
Powertrain:
Heads: AFR 205 or AFR 225?
Intake: Edelbrock Performer Air-Gap
Cam: Lunati Hydro Roller Cam -
55118Carb : Quick Fuel 850 cfm
QFT-Q-850-ANRotating Assembly: Scat
SCA-1-45310BEIgnition : MSD 6AL-2 Box, MSD Magnetic Dizzy
Drivetrain:
Torque Convertor
HUP-51-30Transmission: Built AOD with full manual valve body and trans brake.
Rear end: 8.8 inch. dunno what locker or gear ratio.
My questions are
1. What gear ratio and locker should I use?
2. Would you change anything in this set up?
3. How much HP/TQ would you estimate it at?\
4. Which AFR heads?
