Author Topic: 1987 5.0 idle serge / slight gas hesitation  (Read 1525 times)
68-coupe-289
  • Mustang: 1968 coupe 289
« on: January 02, 2011, 04:03:25 AM »
idle serge from about 1100 rpm to 1500 rpm back and forth ; also slight hesitation when you press the gas what happens is there is about a half second to a full second hesitation????????
i cleaned the throttle body with carb cleaner and it did nothing
Re: 1987 5.0 idle serge / slight gas hesitation
« Reply #1 on: January 02, 2011, 04:06:52 AM »
Check all your vacuum connections.
68-coupe-289
« Reply #2 on: January 02, 2011, 04:12:37 AM »
i will check better but i had an ac vacuum  leak but i closed it off and i am preety sure that it shouldnt serge with a vacuum leak it would just be higher right or am i wrong
68-coupe-289
« Reply #3 on: January 02, 2011, 03:54:26 PM »
i got rid of the idle surge ( set the timing ) but there is still hesitation when i initially hit the gas but after that it runs like a rape date
zebo87
  • Mustang: 87 gt
  • Daily driver: 87 gt
« Reply #4 on: January 08, 2011, 10:35:29 PM »
if its maf converted clean your maf.
68-coupe-289
« Reply #5 on: January 09, 2011, 08:02:20 PM »
no maf
