I lost the post with the question about which injectors to use in a 93 GT. Stock should be 19lb, and with a heated up engine and stronger fuel pump, you can go with the 24. Some guys with really hot engines go up to 30 lb. injectors. Something is going on with this site where I lose posts. I'll get with Thierry to see if we can fix that. You guys have a good time working on your Mustangs, and post often, even if to chat.
