I have a serious problem. I have a 04 gt with edelbrock intake manifold, mmr sheetmetal upper, 75mm TB, Full Exhaust LTS ETC....410 gears, Vortech V! S-Trim w/ 3.33 pulley, 3 core front Mount intercooler, no name BOV, sct 90mm MAF, 42lb injectors, 255 pump, KB BAB. This car will only put down 350RWHP 334RWTQ. AF ration was 11.5 and timing was 17degrees, My tuner and I cannot figure out what the hell is going on, its making 10psi at 6200RPM but those numbers are horribly low for the mods. We did a compression check and all looked good. If you have any idea on what the hell is going on I would much appreciate it. Thanks
