Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Contact
Login
Register
Forum
Technical forums
4.6 Mustang technical forum
Topic:
possible bad tps sensor?
Pages:
1
Go Down
Author
Topic: possible bad tps sensor? (Read 7728 times)
04gtbay
Mustang: 04 Mustang Gt
on:
December 07, 2008, 04:32:03 PM »
OK, WOT at 4000rpm car stumbles/stalls for a split second then is fine, this only happens in 2nd gear. happens at same point every time. have been told possible tps sensor, any suggestions/comments?
D Gage very newbie
Mustang: 1979 MUSTANG COUPE &1985 MUSTANG V8 HATCH
Daily driver: 1985 HATCHBACK MUSTANG TITLE SAYS LX/GT?
Re: possible bad tps sensor?
Reply #1 on:
December 09, 2008, 12:40:58 PM »
my 85 has done that it was not a tps my car is injected so i have one. One of the easiest ways i have found about tps does it also idle erratic in neutral or park? while its idling in neutral or park unplug the tps if it goes does not change then definitely it is bad you can always take it to auto zone they test tps off the vehicle for free
04gtbay
Reply #2 on:
December 13, 2008, 08:48:54 PM »
sometimes idle well go up and down a bit as soon as motor is under load, but only when car is first started. will try what you said though. thanks for advise.
Gender:
Reply #3 on:
December 14, 2008, 06:44:46 PM »
By being under load, do you mean when you put it in drive? Under load to me means going up a hill and you floor it. Then, you are no longer idling.
Pages:
1
Go Up
Forum
Technical forums
Topic:
Navigation
Used Cars for sale
Ford Mustang classifieds
Powered by
EzPortal
