Author Topic: oxygen sensor question  (Read 8386 times)
rockitman
  • Mustang: 2002
  • Daily driver: 03 z71
« on: December 11, 2008, 04:56:48 PM »
does my 02 gt have a narrow band oxygen sensor or wide band
Re: oxygen sensor question
« Reply #1 on: December 11, 2008, 05:54:23 PM »
All S197's came with narrow band 02 sensors.  In order to get a more accurate reading, you will need to put in a wide band sensor.  If you don't have cats you can use one of the rear O2 sensor bungs. If you do have cats you'll need a new bung welded in upstream of the cats. Doesn't matter if it's driver or passenger side.
__________________
rockitman
  • Mustang: 2002
« Reply #2 on: December 11, 2008, 08:18:54 PM »
the reason i ask is im wanting to run a air fuel gauge, do you mean i have to put in another oxygen sensor before the cats? thanks Don
« Reply #3 on: December 12, 2008, 03:48:51 AM »
Yep, an AFG requires you to have to put in a wide band, and if you have cats you are going to have to put in a new bung upsteam from the cat.
gwallis
  • Mustang: 1999 Cobra
« Reply #4 on: December 24, 2008, 01:05:16 AM »
Couldn't you install a o2 sensor bypass or a module that bypasses it some how for more HP?
« Reply #5 on: December 24, 2008, 09:39:26 PM »
That device connects to the original 02 sensor.  So, it doesn't answer the original question.
