1970 Mustang Boss 302
Mustang girl
1977 Mustang Cobra II
100 0886
Saint Martins, NB Canada car show
Author Topic: Help with low rpm misfire  (Read 1843 times)
eddioso
  • Mustang: 98 GT
tomlg2003
  • Mustang: 1967 Convertible
  • Daily driver: Only to a few shows - trophy every time!
Re: Help with low rpm misfire
eddioso
  • Mustang: 98 GT
tomlg2003
rich96cobra
Hello there!
Keep us up todate.....
 ;D
Rich
1200 to 1400 misfire any gear
4.6 Mustang technical forum
terryschu 1 234 Last post September 18, 2008, 10:47:03 PM
by Redneck4.6
