  • November 19, 2008, 04:10:17 PM *
  • Welcome, Guest
Glen's Mustangs
1969 Mustang 302
1973 convertible
1970 Mustang Boss 302
460
Author Topic: Help with low rpm misfire  (Read 1840 times)
eddioso
  • Mustang: 98 GT
tomlg2003
  • Mustang: 1967 Convertible
  • Daily driver: Only to a few shows - trophy every time!
Re: Help with low rpm misfire
eddioso
  • Mustang: 98 GT
tomlg2003
rich96cobra
Hello there!
Keep us up todate.....
 ;D
Rich
1200 to 1400 misfire any gear
4.6 Mustang technical forum
terryschu 1 233 Last post September 18, 2008, 10:47:03 PM
by Redneck4.6
