Author Topic: Headlights not right...  (Read 2965 times)
martinGT9
  • Mustang: 2000 Mustang GT
« on: January 07, 2010, 11:48:49 AM »
I just recently replaced the bulbs inside my headlights and to do so I removed the headlights. When I put them back in the headlight rubber seal was not flush against the car (as shown in the picture). The drivers side headlight is fine, but the passenger side isn't. Anybody have any ideas of how to fix this problem?  ???
stang98
  • Guest
Re: Headlights not right...
« Reply #1 on: January 07, 2010, 11:54:35 AM »
Have you tried to adjust them at all? That could help a bit  :-\
martinGT9
« Reply #2 on: January 07, 2010, 11:56:57 AM »
How would you adjust them? I've tried a couple things but it doesn't want to budge.  :-\
« Reply #3 on: January 07, 2010, 04:16:21 PM »
Make sure the screws that hold the bucket on are tightened equally.  Unscrew them and slightly tighten each one, then eventually tighten them both the same.
stang98
  • Guest
« Reply #4 on: January 07, 2010, 06:53:45 PM »
the adjusters? They don't help?
Fordfan
  • Mustang: 2003 Mustang GT Convertible
  • Daily driver: 03 Mustang GT, 06 F150 Harley Edition
« Reply #5 on: January 19, 2010, 09:07:10 PM »
if it came off the headlight you need to attach it back on the front section. if it wont stay use some adhesive, if you can move the headlight up and down make sure it seated all the way into the fender and make sure the retainer pins went all the way through the headlight brackets on the back.
