Author Topic: Changing a starter  (Read 7626 times)
Jerry Baker
Changing a starter
« on: May 11, 2007, 11:11:47 AM »
Ok everyone we all know Im not a mechanice so here is my question.
How hard is it to change the starter on a 98GT 4.6 motor?
Would it be better to take it to a garage or not?
  • Administrator
    • Used cars
  • Daily driver: Sunfire
Re: Changing a starter
« Reply #1 on: May 11, 2007, 11:53:44 AM »
I am not sure about the 4.6L Mustang but I replaced starters in different cars with no problem.
First of all you have to make sure the battery is disconnected before you do it. Then, you should be able to access the starter from underneath the car by the bellhousing. Disconnect all the wires (take notes about the wires locations). Unscrew all the bolts surrounding the starter and it should come out. After you reinstall it, you might need some shims underneath the starter if it gets noisier when you run the starter.
« Reply #2 on: January 28, 2008, 09:31:09 PM »
Thierry is correct.  Just unhook the battery cables and take off the two bolts that hold the starter to the bell housing.  Piece of cake.
