Author Topic: 2007 V8 starting problem  (Read 1712 times)
rickgower
  • Mustang: 2007 GT Premium
« on: December 14, 2009, 04:05:45 PM »
A couple of times in the last fortnight I have gone to start the car and with clutch pedal on floor as normal, the starter kicks, dies, kicks, dies like it has a bad connection...luckily in the end the engine starts. Both times, the car has been unused but garaged for at least 24 hrs, and in fairly cold damp conditions.... any ideas on easy things to check?
Thanks
Konrad
  • Mustang: 2007 GT 5 speed
Re: 2007 V8 starting problem
« Reply #1 on: December 15, 2009, 01:40:02 AM »
I have an 07 as well and you probably know that the clutch has to be all the way to the floor in order for it to crank. I have had a few times where I'll lift my foot even a tiny amount and it will stop cranking. If something is wrong with that switch, or something got under your clutch pedal (floormat?) then you could be only just barely closing that circuit on the clutch pedal. I would probably look into that. Just an idea hope it helps.
Last post March 04, 2006, 11:51:20 PM
by GT350Man
Last post November 24, 2008, 03:24:33 PM
by gwallis
Last post June 22, 2009, 10:25:56 PM
by Jaime_302
Last post September 17, 2009, 11:37:00 PM
by Jaime_302
Last post January 21, 2010, 09:13:57 PM
