Author Topic: 2003 radiator fan only starts when you turn on air conditioner switch  (Read 5804 times)
ron56
  • Mustang: 2003 GT
  • Daily driver: me
my radiator fan froze so i replaced the whole radiator fan assembly & a 50 amp burnt fuse on my 2003 4.6 mustang GT. now the fan only goes on when you turn on the air conditioner switch & the air conditioner doesn't blow cold air. all fuses are fine. i also replaced the cooling sensor & that didn't help. the ford dealer said it could be a burnt aluminum wire or the computer is not communicating with the new radiator fan & has to be adjusted, the new fan motor assembly wasn't a ford part, or the CCRM(constant control relay module) $625, or the PCM(power control module) $192. the dealer wants to charge me $100 just to tell me what's wrong. it will be applied to the bill. any ideas. has anyone had this problem. it's my fault, i didn't use the car for a extended time.
ol dirty doug
  • Ol' Dirty Doug
Re: 2003 radiator fan only starts when you turn on air conditioner switch
« Reply #1 on: January 06, 2010, 06:34:32 PM »
i think its the cooling fan relay, but i do not know if your car has a seperate one, or if it is interigrated with some other componets?
