Hi all,I got a 98 mustang gt 4.6 with a problem[or maybe problems!]
First of all she is down for power I checked the fuel pressure and its only 10 psi, REPLACED,FUEL FILTER,FUEL REGULATOR,FUEL PUMP,AND STILL NO INCREASEi ALSO BLEW OUT THE FUEL LINES,CAN ANYBODY HELP.
CAR STARTS AND IDLES FINE,PRESSURE AT IDLE IS10 PSI WITH REGULATOR AND IS 20 PSI WITH REG VACUUM DISCONNECTED.IF YOU CRIMP THE RETURN LINE THEN THE PRESSURE INCREASES BUT THIS DOES NOT HELP WITH POWER.
I SCANNED THE VEHICLE AN NO FAULT DATA PRESENT.
